Brake light help in a auto to manual swapped ej1
942drcoupe
Superman
so the only post i found relating to this had no actual answer to the question. so when i hit my brakes my dash lights come on and my parking lights. all my wiring is straight factory, the problem is I swapped a manual tranny into and automatic chassis, does this sound like a brake light switch problem? I don't wanna waste the money on the switch bc i cant return it if its not the problem im just curious if im missing something in the swap process that may cause this. thnx
MistahJuice
100% real juice
How did you wire the reverse lights? I remember when I did this I just ran 2 wires from the reverse light switch on the transmission to the plug under the shifter. Did you do something different?
942drcoupe
Superman
i never messed with the reverse lights they have always worked just fine. my swap is also a b18b1 swap obd1. if it makes a difference. i also noticed someone posted a problem just like this in the interior section, that involves dash lights only when braking. maybe someone knows thnx
