Brake Light LED Swap Issue
HeX
Authoritah, respected.
Im upgrading my brake light bulbs to LED 7443 bulbs and when I press on the brake pedal without keys in the ignition, theres a beep inside for the duration I hold the brake pedal. Is that some sort of warning that the car thinks the brake bulbs are out since theyre LEDs? If so, will i need to install a resistor for each of the bulbs? FYI, both brake filaments work just fine.
b16lewis
That is the car saying the lights are on and it is not running. something is screwed up in your circuitry
HeX
I checked on it again this morning before going to work. It turns out the replacement light harness I used isnt wired correctly and caused the issue. I even noticed it caused the gauge cluster to light up when the brake pedal was pressed. That was surprising.
PHAHEEM
Yeah I'm using an LED 7443 bulb for my 3rd brake light and I don't have any issues
