Brake light problem!!
bigpatskize
Fat boy with AWD
Hey guys i put my newly painted taillights on last night and i went to check them and my far left brake light does not work when my headlights are turned off, but when i turn them on they work i have checked my fuses and the bulb and i am not a wireing expert so please some help will be nice!!
TorGa3iGhT
"torga eight"
u can try getting a volt-meter if you think it might be somewhere in the wiring...i think it'll run u like 20 bucks or something...then u can check to see if there is current going into certain areas...maybe help u narrow down the source of the problem?
Did you check both filaments in the bulb? i think for the tail lights there is a dual filament. Otherwise, not too sure....u got a strange problem there...haha
silvertuner98
sounds like one filament is out. take the bulb out, put it in one of the other brake light sockets and see if it works
NOFX
I'm NOT eran!
Do you mean that the taillights light, but the brake light will only light when your headlights are on?
bigpatskize
Fat boy with AWD
yes my far left brake light on the drivers side will not work with the headlights off but when i turn the headlights no it works :???:
bigpatskize
Fat boy with AWD
i may try that thanks!!
MECP
All you did was paint your tail lights right? Meaning, you just un-bolted the necessary bolts, twisted off the bulbs, and then painted right? After you got done painting, you put your tail lights back on, in the reverse order? As stated above try swapping out your bulbs. If that fails... How did you check your fuses? Pulled them out and eye balled them? Or did you have that mini-fuse test light thing? If you have, or can get access to a digital multi meter, that would be perfect.
--- Even though your fuse LOOKS to be good, that doesnt necessarily mean it is. Best way to check is with a DMM ---
