Brake lights don't work
rtovar
So I have a 2000 Si and I don't know why the brake lights are out. The run lights work perfectly and I've tried changing the brake light switch and I've checked the fuses. Anyone have any ideas as to what it can be?
CO671
Usually the things to check would be this:
1) Fuse
2) Bulbs
3) Brake Switch
4) Wiring harness
Mysteryemotionz
Test all at the same time
Using a multi meter check to see if your getting voltake at the connector. If you are the bulbs r no good. If your not replace fuses n relay with known working ones n test at the connector again. If this fails your gonna have to work your way down the harness n find the culprit
Sent from my LG-E739 using Tapatalk 2
