Break upgrade hatchback 93
rafacbtz
hi folks
i replaced the rear brake on my hatch but i dont like how feel the brakes....
reading some blogs, mention that i need to replace the master cylinder and the valve from the integra.
can you confirm this information.?
if this is necessary can you provide the part number o model of the master cilinder and valve?
best regards.
lethal6
Your Mom's Moderator
1st) We don't know what you are working on (trim, model, motor, modifications, what brakes you put on it, etc).
2nd) We don't know what "upgrade" you plan on doing (from what car, model, trim package, etc).
3rd) Would help if you linked these "blogs" that you got your information from if you want confirmation if they are actually correct. That or you are going to have to make an account on the other websites you got the information from and ask them if you can't provide the information for us to critique.
jameswanser
Member
if switching from drum to disc rear brakes, yes you normally need to change the proportioning valve on the firewall. You likely have a 30/30 proportioning valve, and will need to change to a 40/40 valve. The 40/40 valve can usually be found on a 1990-1993 Integra. Because my car isn't equipped with ABS, I also upgraded my master cylinder as well (I pulled one from a 92-95 Civic EX that came standard with 4 wheel disc brakes, and no ABS). Sorry, I don't remember the size of my new master cylinder (perhaps 7/8ths?)
rafacbtz
Sorry man,
Well have a OEM civic hatchback 93, swap integra LS 1994 B18B1, and rear disk brake upgrade from integra 94,
Thanks master.
