Broken Gauge Needle!!!!!!!!!!!
NoBoost
138,000 Mi. EM1
I was removing the reverse glow gauges on my recently purchased EM1 today. I tried to be so careful but i managed to snap off the needle on my temperature gauge. Is there any fix to this? I tried to Epoxy the THIN needle back into place but it just didnt work. HELP!
99cleanCIVICex
Same thing happend to me, ITS NEVER GOING TO READ THE SAME WAY!!! Its always going to be a little off, I end up getting a new cluster................
NoBoost
138,000 Mi. EM1
if i go to the junkyard and find another cluster, can the needle be removed from the sensor and then reassembled into my cluster? or are they a one time fittment?
c_diddy
drove through a tree
I doubt you'll find a si cluster at a junkyard...but if by chance you do, you can't just take the needle off, you'll end up breaking it. you should always try to avoid messing with the needles. but what you're going to have to do is take out the entire temp/fuel guage and replace your old one with it. just be careful when you do it, all that stuff is very sensitive....
NoBoost
138,000 Mi. EM1
nope, hondaautomotiveparts.com doesnt have it. im f**ked.
NoBoost
138,000 Mi. EM1
do you guys think that the honda dealership could get the new fuel/temp gauge with sensors???
1999CivicEX
May cost a pretty penny but I don't see why they wouldn't be able to get you one
jaypee0930
Yes, I paid $45 for fuel/temp gauge..i broke mine 4yrs ago...and i installed it my self...hmm im just wondering why do u need sensors?
NoBoost
138,000 Mi. EM1
well im not sure if i need the temp sensor because the peice that i broke off is not the orange needle. its the small, metal needle that connects the orange needle to the sensor. i dont know if they come apart and then can be put back together. thats why i think i might need the whole gauge face, needle, and sensor all in one. yea know what i mean? p.s. im posting up pics of my new em1 so be sure to check em out
slocivic
how to fix the temp gauage
I did the same thing and its only like $30.00 my cost from the dealership. not real expensive but I have an ex so it could be more for the si.
c_diddy
nope, you broke it. the needle does not nor is supposed to come off. like i said, you're just going to have to get the temp/fuel gauge and replace that itself, not the whole entire gauge cluster. you'll be able to order another one off of Honda, but ddparts could probably get it for you at a cheaper price.
charles_00Civic
CC'S Longest Running Noob
same thing. I found a cluster with like 2xxx clicks less than mine so I put it in. Um. Your best bet is to just buy a new one. Its 85 canadian up here. So maybe 60 or so in the US. Then take the old one out (4 screws or something) and put the new one in. Reverse glow gauges are a b***h!
c_diddy
NoBoost said:
how do i go about that
If you're not sure about what you're doing, then I would highly recommend having a professional do it...
but you'll basically end up taking everything apart...I did it about two years ago but so I can't really remember what I did exactly...take off everything on the front of the cluster, i think the bezel should be the last piece, then you should just have the seperate gauges. there should be 2 or 4 screws behind the fuel/temp gauge, so you unscrew that and the gauge should just come out...then just piece everything back..like i said, I dont really remember what i did so be very careful and if you're unsure, have a pro do it.
00Civic4DR
yo man im am th king of broken clusters and u can go 2 honda to fix it but they will charge u and arm and leg and they dont even fix the cluster they juss get a new 1 and put ur miles on it so if wanna keep track of ur miles i would do that but if anything jus get another cluster.sorry to hear about ur little f**k up ;p;
qwertyuiop
Rockin' Out the Sedans!
You buy a new gas/temp gauge. NEVER f**k around with your needles as they are very fragile and shouldn't be touched. 6 screws at the back is the aswer. then remove it. IF you fin a new Si Gauge, Remove your old speedo from your Own Si Gauge which has 4 screws at the back and install on new cluster.
TigBitties
Frame Bangin
this is from five years ago, just so ya know
