ncegen
I am looking for oil and coolant leaks as I am losing both.
Found radiator leaking at junction of plastic and metal, no problem to replace radiator.
Oil is a different story, can't find any drips and car doesn't really smoke except occasionally when you first start it up and a few minutes afterward.
Exhaust manifold was smoking so I pulled the heat shield back and noticed small bubbles slowly coming through the threads (out from the nuts) of two of the exhaust manifold studs. I am going to assume these studs screw into the water passages in the head?
I can't see if maybe the headgasket is split behind the manifold or maybe the head is cracked?
It is a '97 D16Y8 Vtec motor 300,000 miles.
Any help or info would be appreciated.
Thanks.
Thanks.
