Built b18c, worth it?
honda_skater
My friend is buying a dart block for his build so he offered to sell me his set up. I'm wondering if it's worth it. Any advice and help is appreciated.
Block:
Itr block
8.5/1 forged pistons (I think they are SRP)
Ls forged rods
Arp head studs
Acl bearings
Hondata gaskets
Jegs oil pan
Head:
GSR head with stock intake mani
Type r header
Itr transmission
Axles, linkages, GSR computer and mounts included as well.
Head and block were fully tanked before rebuild. Head is port and polished with 3 angle valve job. He is keeping his itr head because it has full valve work. He said I could get it for $2,000. Is that a good deal? Thanks in advance.
Wreckless Hype
¯\_(ツ)_/¯
Sounds pretty decent. I think a fully assembled, ready to drop in ITR block like that goes for around $3500, but that included tranny, ECU, etc from the same car.
Look at what you're getting, source what you would need, and maybe compare it to other complete packages. Check to see what the other goodies go for that he threw in for you. If it's a full turn key swap, probably not a bad deal.
honda_skater
Yeah it's a complete swap. He's buying new axles, mounts, and everything. So it'll be a full bolt-in swap. Thanks man.
