Mccluskey9rsx
Ok so my dx coupe which has 210,000 miles was burning coolant. you could smell it burning, you could see the smoke coming out of the exhaust, and you could also see the bubbles coming threw my radiator when you hook the funnel up to it.
I went to replace the head gasket, so I cleaned the head and the block, put a straight edge to it to check to make sure it wasn't warped, put the head on and did the two sets to tourgue the head down (first set 22 ft-lbs, second set 49 ft-lbs) put everything back together..
now it smokes so bad that I can't even drive the car. It constantly pours out smoke from the exhaust, i also checked the oil i didnt not see any oil mixed with the water. Has anyone had this same thing happen to them thanks in advance
