Originally posted by shizznittz
I recently purchased a generic cold air intake off of ebay because I figured I should spend more money on buying an exhaust. I'm pretty sure I installed it corecctly but when i push on the gas at a certain angle, a high whistling sound comes out. What do you think could be causing the problem?
When you say you push on the gas and you hear the whistling sound, is your car slugish like, or is your car movin. If your car is accelerating at normal, or better than normal, than that whistle is good. If not, you may have a whole other problem entirely.
You also, like everyone else said, prolly just need to check if you have a leak. If you havent already tried----try poppin your hood, and with the engine runnin(DUH), rev your engine with the throttle, and listen for any suction/whistle sounds. If you just hear it coming from the filter, than you should be good to go----no leak. But.... well im sure you already know. Jus make sure everythings tight.
Also lets see engine pics for reference
