i need help i also have a 95 sol w/ turbo b18a converted obd1 the car sputters from 1,000 rpm to 2500 can rev as high as i want but when u let off it kind of sputters then dies out so i adjust ignition timing gradually all the way to the one side runs better but not perfect and cant adjust it any further. im running a base map neptune from jeff evans. do you think i need to adjust cam timing or run it to break in w/o boost and just let him do everything else??? or adjust cam degree???? anyone have experience????
