camber kits
stockdx
I need one bad.....I am one the ground and there is hardly any tire touching. I see soooo many different kits and prices I don't know what im supposed to get. someone plese enlighten me. thanks
Neon_ice
security at its finest
yep yep, search works wonders, and so does posting in the right spot, buut since ur new, its all cool 8)
civic hatch
SPC, Skunks , Ingalls all make camber kits with various degrees of adjustments.
for a mild drop you need a kit with about 0-1.5 degrees of adjustments
for the front new adjustable ball joints usually work
for the rears you can use the washer trick just add washers to the rear upper arm bolts (1 washer for about .5 of a degree of negative camber
for a serious drop you woould ned a kit with 1.5 and greater
for the fronts you usually need a upper A arm. the rears are going to be a new upper arm that is adjustable
there is a lot of info on this site so just look around and you ll find more info.
