Can a oil return line go in a circle to the oil pan and not just stright down?
EF Honda EF
Ok well i have a question. My oil return line cant really go down to the oil pan because the line will crimp. So i kinda looped it around in a circle. I know the oil feed is pressurized and would work but is there enough force in the oil return to loop around into the oil pan. Lookie
Matt.
noooo don't do that. You'll have a blown turbo in no time, Just cut the damn thing!
Shiznit
Stickin it to the Man
then support the line somehow so it doesnt crimp or switch to a steel braided line
EF Honda EF
that is what i did. it still barley fits but i think it will work
i still need to put the other elbow on. Has any one done dsm injectors before? i need some help
jason_guy_yeah
With dsm injectors, you'll need to a resistor box (or sauter them in) and port out your injector holes.
Matt.
You most always would want to use a steal braided line for oil return, over time that hose will deteriorate and case oil leaks and the like.
EF Honda EF
its an obd0 crx so i already have a resistor box.
I guess once the line starts leaking ill replace it. i cant use a steel braded line cause there isnt a way to get a fitting on the turbo side cause its a volvo turbo from the junkyard.
jason_guy_yeah
Oh, didn't realize it was for the crx
EGlude Attitude
All Motor Militia
Ummm....why is your oil drain facing the block and not on the bottom? I'd suggest re-clocking the center section of the turbo so that the drain is facing downward. That'd be a good solution to most of your problem, the way that drain is now, I'd think that oil is going to get backed up and eventually blow the seals.
I was always under the impression that turbochargers were partially gravity drained.
Maybe I'm wrong....:what: ...but I doubt it...:lol:
Phantom Civic
Never Satisfied
That will not work either. The drain needs to be almost perpindicular to the ground. You can go in either direction 30*, if you go more you might have problems.
spoolincivic
better than you
yea i was wondering the same thing, that oil return needs to point down. and if you still have crimping issues is try to get one of those molded hoses from an auto parts store
