can i boost on a non o-ringed head?
jsnm
Not Available
i had to take my head to a machine shop and they resurfaced it and completely removed the o-rings i had on each cylinder.should i have these put back on for added safety under boost or should i not worry about it?thanks.jesse
N/A_SI
CCCC #111
unless your boosting ahellalot then no
jsnm
Not Available
i will be pushing at least 15-20 pounds but not all the time,i will run 8-10 all the time
slambed_civic
what the hell o rings are you talking about? and wher ein DE are you from?>
N/A_SI
CCCC #111
i would on my car if boosting 15-20 so yes to be safe and to be headgasket headache free.
jsnm
Not Available
im not sure if i got the o-ring name right,but im talkin about the metal rings that are put into the underneath of the head and goes around each cylinder to prevent any s**t from happening.
N/A_SI
CCCC #111
in the more serious aftermarket wourld when building a moded engine you can get the head or block o-ringed for added combustion sealing strength.
jsnm
Not Available
no sleeves,but its fully built along with a blockguard and the heads rebuilt as well.
slambed_civic
piston rings. thats what they are... if the engine is fully built then you shouldnt need rings....
jsnm
Not Available
yea,i kind of thought i might not need them,but however the guys at the machine shop said they recommended puttin them back in if i was going back to boostin,which i am now.i just dont want to have to rip off the damn head again and spend more money,im already spendin a whole lot on a hondata to get this thing runnin again,
N/A_SI
CCCC #111
what??? not to be an ass but do you understand what we were talking about? slambed_civic
evan2
Search owns you
dont need rings in a built motor? lol what are you smoking
yes you need rings I dont care how built you are, you need rings you need rings you need rings
what O rings are you talking about dude...
Ravage70
u dont need the orings just get an mls headgasket from honda
Declectic
SeanJohn1802
wow a lot of mis-understanding in this thread, hell i might as well join in
you dont need a headgasket, they're over rated :P
Dr.Anus
proctologist
Totally, don't worry about a head gasket; just run a bead of caulk in between the head and the block.
jsnm
Not Available
ok,ive realized alot of ppl dont know what i am talking about,so i tried to draw a diagram around the head to show you where these rings go.and for god sakes im not talking about piston rings.
