can it be head lift from the studs or a blown gasket!!!!
JRESTRADA
SO HERE IS THE PROBLEM I HAVE A EG WITH A D16Z6 AND EVERYTHING WAS NORMAL TILL I SLAPPED A GREDDY turbo
ON IT THE PROBLEM IS MY CAR OVER HEATS I CHANGED everything FROM RADIATOR TO FAN THERMOSTAT AND FAN SENSOR THEN I NOTICED THAT WHEN I WILL HIT BOOST RADIATOR FLUID WOULD SPIT INTO THE OVERFLOW THIS HAPPENS ONLY WHEN I HIT BOOST AND IT DOESN'T SUCK IT BACK UP AFTERWORDS DOES ANYONE KNOW WHAT THIS CAN BE ?? ok and there is no oil in water or water in oil?
slowhatch
torque?
Get some ARP head studs and a new headgasket.
Gonzo
Tin Foil Member
you have a blown headgasket. do what he said ^
ekturbo
yea it could just be head lift. HG and arp studs are a must. I would do a leakdown test to see where the leak is coming from to be sure. Have the head checked for a warp since it was over heated when you get the head off for the new gasket and studs
slowhatch
torque?
how if there is no oil in my water or other way around ? will this fix my overheating prob?
I've only seen coolant and oil mix in bad headgasket failures and yes the ARP's will fix your overheating issue.
