car bogging and apexi went blank
yurch0111
i have a 93 civic with a b16 and a turbonetics turbo kit i have an apexi vafx2 controller and my car is bogging and dieing down and now my apexi restarted wat would b my best way to fix this
jason_guy_yeah
Go get your ECU chipped and tuned at the dyno. AFC hacks are bad for your engine.
civic98turbo
I'm back ....
yea afc's are ok for n/a tuning....but for boost....stand alone is best.....but at least a chip
yurch0111
but for now wat should i do so i dont hurt it u no anyways
civic98turbo
I'm back ....
what i would do....is not drive it...if you must drive it...stay out of boost.....if you can't stay out of boost....bump your fuel settings up across the board...
slowhatch
torque?
if it was reset then just put in the correct sensor type and car no. and fuel settings. sounds like you're waaay to rich and you're flooding the engine.
if its not fuel then make sure all the connectors at the ecu are on there good, i taped mine after my car did what you described (my vacuum also measured 100kpa which is 40kpa over normal operation).
oc_civic
he may not even be using the vafc to increase fuel pressure based on boost.. he simply stated that he has a vafc that is going off and the car is bogging
first as stated check the connections
secondly any check engine lights
if so what codes are the ecu throwing?
