Car hesitates at low rpms
Whatever_emily
Hi I have a 1988 civic hatchback that has been acting weird for a while but is becoming more prevalent. First off every once in a while it has a hard time starting. Secondly, whenever the car is under a load at low rpms it wants to bog out. If I keep the rpms higher around 3000 I have no problem. Any help or tips on what could be wrong would be appreciated. I checked the codes and it was throwing a one and I read that means it has a bad o2 sensor so I replaced that but still doesn't run right. Thanks
taluzer45
4 Banger Deluxe
Try changing the spark plugs, wires, cap and rotor, check the air filter, and check the fuel filter!
baytownhatch
Check all your vacuum lines. Could have a vacuum leak. I remember having a 92 avenger that would do that and if I stopped completely it would die turned out to be a bad egr.
Mishimoto
Product Manufacturer
I would also recommend a tune up as taluzer said, especially if there are no records of this being done recently. Vacuum leak also seems like a possible cause, try spraying starting fluid or carb cleaner on your vacuum lines. If the idle changes, you have a leak there.
This is an inexpensive way, most shops will perform a smoke test to locate the leak.
