Gotem91
Hi, I usually search a lot in the forums to see if i can find an answer on a problem I have but mine might be more unique so I decided to start a thread and get some ideas.
Yesterday my Auto 99 Civic ex started sputtering right after i filled up with gas, I've never had this problem before. I have replaced the spark plugs and wires, Fuel filter, air filter, replaced cat with high flow cat, and new exhaust system. I did all this in the last 2k miles. Plus I have no check engine lights on. So i'm pretty confused on why my car started sputtering. I checked all the plugs and wires today to see if there was any issues and there isn't. The car only sputters at what I noticed at lower Rpm's or going up steep hills. If i'm in a lower gear and the Rpm is higher, It runs fine, It also idles perfectly fin. Is it Possible for the gas to be bad? Any Input would be greatly appreciated!!
Thanks!
Thanks!
