car will crank but wont start
mthury001
new kid on the block
the other day my car ran fine till i shut it off then it would crank but wouldnt start. i replaced the plugs cap and rotor. it then started and ran fine.i took it around the bolck and then my girl stalled it in the drive and now it wont start again. i dont know what else to check or replace help please
RichardCrainium
check your fuel pressure make sure your getting gas if you are check your spark at the plugs if you have fire check the timing and make sure it didn't jump time my 00 ex did the same crap this morning I have no spark at the coil but I am stuck there tonight cuz I cant see if you don't have spark at the plugs I can tell you how to check the coil and beyond if you need help let me know
mthury001
i just replaced the main relay and it still wont start. if it did jump timing how can i check. and yes please tell me how to check the coil
Don't throw parts at the problem. Do some basic diagnostics.
Does the fuel pump prime?
Is there bright white spark at all 4 spark plugs?
Any CEL codes?
RichardCrainium
Pull the cap and rotor and dust cover off the distributer the coil has a metal spring coming out that's what makes your spark. Ground a test light on the strut bolt and hold the point off the spring about 1/8-1/4" off and have a buddy turn the motor over if you have a bright white spark then you need a cap and rotor if no spark then you have to check the spark module. To do this you use the test light and if you look at the coil it has two wires on the bottom of it one is pos(+) and the other is neg(-) you need to put the test light on the neg. They are marked + or - With the key on the light should be on have a buddy turn the motor over again and the test light should rapidly blink. If it stays lite or turns off then your module is bad. Replace it and check the coil again because I have seen both go bad. Just make sure that you ground the test light properly or you will zap the ish out of yourself.
the only way to see if the timing belt broke or jumped is visual inspection. check if its broke first. if is not then you have to line up all the timing marks and see if everything lines up or not.
mthury001
update on it. ive replace almost everything but the distributor housing . and im still not getting spark. its been throwing a cel sincei bought it. the rotor will spin which leads me to belive that the timing belt isnt broke.
RichardCrainium
stop throwing money at the problem figure out what is broken then replace it. there are videos all over youtube on chasing the problem down check out ericthecarguy he has a video on finding the issue on a 6th gen his technique is basicly what I told you to do above if you have no spark and basicly a new distributer it may be the computer itself or something stupid like a fuse. Just stop wasting money away on parts you don't need diagnose not guess bro.
