Alright, so Im throwing CEL 16, for fuel injectors, which is causing my car to be thrown into limp mode, making it impossible to tune / run pass 3,500 rpm. Im trying to figure out what could be causing the code. All four injectors are spraying (or else the car would be running like crap - it idles fine). The dsms are installed correctly with obd0 clips and a resistor box, the injectors have 7 ohms of resistors to each (tested using a multimeter) and the wiring has been double, tripple checked. Any ideas of what else it could be?
