matt in tulsa New Member Jun 22, 2010 #1 Will a center panel from a 99-00 fit in a 96-98? Will the A/C controls work? I like the controls in the 99-00 better than the 96-98.
oc_civic .................... Registered VIP Registered OG 5+ Year Member 10+ Year Member Jun 22, 2010 #2 matt in tulsa said: Will a center panel from a 99-00 fit in a 96-98? Will the A/C controls work? I like the controls in the 99-00 better than the 96-98. Click to expand... 99-00 electrical controls 96-98 mechanical controls you can swap.. but a lot more work than just the cosmetics..
matt in tulsa New Member Jun 23, 2010 #3 oc_civic said: 99-00 electrical controls 96-98 mechanical controls you can swap.. but a lot more work than just the cosmetics.. Click to expand... oc thanks for your input. i was in class when i posted it and had a chance to look at the service manual during a break. The air mix control is a cable type on the 96-98 and motor controlled on the 99-00. Thanks again for the reply.
NIKE H34D Slow and Loving It Registered VIP 5+ Year Member Jun 23, 2010 #4 It can be done.. look up the swap, there are write ups all over. Not worth it IMO. and yes I read your last post. Just making sure you know its not too uncommon
