changin psi on internal wastegate?
Evan.
iTrader EVERYthing
theres a spring inside the wastegate that is the variable for the amount of psi passing through..
Theres different rating springs that you can buy, eg. 7psi spring, 10 psi spring, 12psi spring, etc. etc.
Steven.
Formally Green 91
i have a extra 3.7 pri spring, but its for a external wastegate. dont think it will fit in a internal one, you need to find a adjustable internal wastegate.
slowhatch
torque?
Chaos said:
how do u chage the psi on a internal wastegate?
x2, i always thought bov's controlled it on internal gated turbos, oops
Matt.
are you looking to run more or less boost then the waste gate is set for? Because if its more, the spring in the waste gate already should work, its just you can't go under that set psi of the spring. You would also need a boost controller.
Steven.
Formally Green 91
yeah they work. are you goign tot run 10 on a stock engine?
