Check engine! Help!
Jersey_Devil
OK so my girl calls me yesterday asking about oil, so I tell her what kind to get, she gets it and puts it in. When she gets home she tells me that her check engine light is still on (usually turns on when she is low and soon as she puts since in it goes off) she said its driving funny too. I took it for a ride and it's slow as balls! I stop at advance auto to use code reader and this is what I got
P2646
A Rocker Arm
Actuator Control
System Performance Stuck Off
So I guess my question is.... Is the engine toast? What should/can I do to save it?
D17A2 engine
sent from my obama monitoring device
Did a little shopping around and found this... looks like there's images to go with it but they're no longer available. Either way hopefully it can point you in the right direction!
DTC P2646: VTEC OIL PRESSURE SWITCH CIRCUIT LOW VOLTAGE
1. Turn the ignition switch OFF.
2. Check the engine oil level.
Is the level OK?
YES: Go to step 3.
NO: Adjust the engine oil to the proper level.
3. Turn the ignition switch ON (II).
4. Reset the ECM
5. Start the engine. Hold the engine speed at 3,000 RPM with no load (in neutral) until the radiator fan comes on, then let it idle.
6. Test-drive under following conditions: Accelerate in 1st gear to an engine over 5,000 RPM. Hold the speed for at least 2 seconds.
Is DTC P2646 indicated?
YES: Go to step 7.
NO: Intermittent failure, system is OK at this time. Check for poor connections or loose terminals at the VTEC oil pressure switch, the VTEC solenoid valve and the ECM.
7. Turn the ignition switch OFF.
8. Remove the VTEC oil pressure switch (A) and install the special tools as shown, then install the VTEC oil pressure switch (A) to the oil pressure gauge adapter (B).
9. Disconnect the VTEC solenoid valve 2P connector.
10. Start the engine. Hold the engine speed at 3,000 RPM with no load (in neutral) until the radiator fan comes on, then let it idle.
11. Attach the battery positive terminal to VTEC solenoid valve 2P connector terminal No. 2.
12. Start the engine, then connect the battery negative terminal to VTEC solenoid valve 2P connector terminal No. 1, and check the oil pressure at an engine speed of 3,000 RPM.
Is the oil pressure above 390 kPa (4.0 kgf/cm 2 , 57 psi)?
YES: Go to step 13.
NO: Inspect the VTEC solenoid valve
13. Disconnect the VTEC oil pressure switch 2P connector.
14. At VTEC oil pressure switch side, check for continuity between VTEC oil pressure switch terminals No. 1 and No. 2 in the condition of step 12.
Is there continuity?
YES: Replace the VTEC oil pressure switch.
NO: Go to step 15.
15. Turn the ignition switch OFF.
16. Disconnect the battery terminals from the VTEC solenoid valve terminal connector.
17. Disconnect ECM/PCM connector B (24P).
18. Check for continuity between ECM connector terminal B9 and body ground.
YES: Repair short in the wire between the ECM (B9) and the VTEC oil pressure switch.
NO: Go to step 19.
19. Check for continuity between VTEC solenoid valve 2P connector terminal No. 1 and body ground.
YES: Go to step 20.
NO: Repair open in the wire between the VTEC solenoid valve and G101.
20. Check for continuity between ECM connector terminal B15 and body ground.
YES: Repair short in the wire between the ECM (B15) and the VTEC solenoid valve.
NO: Go to step 21.
21. Connect the VTEC solenoid valve 2P connector terminal No. 2 and body ground with a jumper wire.
22. Check for continuity between ECM connector terminal B15 and body ground.
YES: Update the ECM if it does not have the latest software, or substitute a known-good ECM, then recheck. If the symptom/indication goes away with a known-good ECM, replace the original ECM.
NO: Repair open in the wire between the ECM (B15) and the VTEC solenoid valve
xxBLOOD88SHOTxx
Surge Master
Probably low oil pressure from it running low on oil, code 2646 is VTEC oil pressure switch low voltage.
Check the oil and make sure it is topped off, check connections to the oil pressure sensor and VTEC solenoid.
More than likely there is something seriously wrong, because it should not be constantly leaking/ burning oil to the point that the check engine light comes on.
When was the last time the oil was changed?
GOD DAMMIT XPLOD3R
Jersey_Devil
Two months ago I changed the oil but it leaks bad from the top. I've yelled at her before for letting it get so low the light comes on. I'll go check the connections.
