ElMaq
Hi!
I have a Civic 93 1.5 (D15b7) sedan that never gave me any problems until 2016 when it started the following problem:
When I turn the key on, the Check Engine light is on. The normal is to turn off after 2 sec. When you turn the key, you can't hear the click of the relay or the fuel pump working.
Then I leave the key turned on, after about 30 seconds to 90 seconds, you hear the click of the relay and the pump working. So the light turn off and I crank and immediatellythe car starts fine without any problem.
Once it get it work, the more I drive, the less it happens this problem. Example: when I leave home, it takes 1 minute to turn the light off, but if I stop at gas station, I turn the key on and the check engine light will turn off normal (2 seconds).
Replaced: brand new fuel pump, BN main relay relay, BN filters, BN TDC / CRK / CYL sensors, used ECU.
Gets the same symptom.
I've checked grounds, connectors, all fine. The car never got water inside.
I made the jumper and did not retrieve any code
WHILE CHECK ENGINE IS ON, CAR CRANKS BUT WON'T START
Does anyone have any idea what is this?
regards from Rio
regards from Rio
