Clark Kent
Hi everybody.
My civic 95 try to kill me with this imposible issue.
It overheat when idle for to long,or in city driving,or a steep long hill,especialy when the heater fan is not on.
If the cabin fan is on,no overheating.How it manifest the problem: temperature gage usualy stays below half of the scale.No mather what,before,and also to my other civic 93 does not climb up over a third of the scale.In this case,temperature go over half,close to 3 quarter of the scale and only then the fan swich on the termostat housing kik in and start the radiator fan.At this point changed all temp.relatet semsors.(sending unit under distributor,temp.ECM sensor under distributor,temp.swich on termostat housing-twice last time with a OEm from the dealer,intake temp.sensor behind the intake manifold,).Also replaced water pump,3 thermostats, checked gas leak in coolant,got to extreme and decided to change the head gasket(just to be shure),same thing.In long run everything looks ok,in city driving temp.rise over half.Checked all wiries,replaced ECM,dsame thing . It seems to me that the fan switch on the thermostat housing is the last resort to turn the fan on. Question is: does the ECM turn the fan on also? In what conditions? Checked wire on pin12 on A connector.If touched to ground ,it turn the fan on.I end up soldering a wire inside the ECM puled out and connected to the black-yellow wire directly to be sure that it work.Same thing all over.Any suggestions?
