Droppin' Tacos
Hello Civic Enthusiasts! New to the Forum. Thought I'd share my build with you all. 1995 Honda Civic EX (Gen5 2-dr EX: EJ1). Equipped with Stock D16Z6 SOHC VTEC 4-Banger. This car is my Daily Driver and my Daily Lover. Haven't done too much work to her yet, but I have big plans for her in the near future.
I just washed, Clayed and Waxed her over this last weekend. Also, just changed Oil, Oil/Air/Fuel Filters, Bled Clutch Fluid, Changed Spark Plugs, SP wires and Distributor Cap and Rotor.
Current:
I don't see too many EJ1's around these parts (Gen5 EX/SI 2-dr). I do see a lot of Gen5 Hatchbacks, however. I love them both. (Disclaimer: 2-door Gen5 Civic EX was sold as an SI in the Canadian Market - Just an FYI)
Feel free to give me some suggestions or share your thoughts. I am open to constructive criticism. Let me know what you think, and let me know if you want more Pics!
Current:
- CAI (Fabricated - K&N Filter)
- Coilovers
- Neuspeed Front/Rear Strut Tower Bars
- SONAR Projector Halo Headlights and SONAR Taillights
- Enkei Wheels with Khumo Ecsta Lo-Pro's
- Japan Spec Shallow Side Molding Trim
- Threw a Single-Din Pioneer Head Unit in
- Pushing a 10" Rockford Fosgate T1 (DVC - Wired at 2 Ohm)
- High-Flow Intake Manifold
- Exhaust Header / Full Exhaust Upgrade
- Sway Bars
- Short Throw Shifter
- Going to replace Underhood / Shifter bushings with Brass Bushings (Don't care for squishy bendy OEM bushings)
- Going to replace Trailing Arm Bushings and probably replace Rear Lower Control Arms.
- Possible Camber Kit (Just to have the option and make friends jealous) Not a hug fan of uneven Tire Wear. O_o
- Boot on Slave Cylinder is getting old, probably replace the Slave Cylinder soon.
- HO Alternator (For Audio Setup)
- New Battery (Pretty much plan on doing "The Big 3" upgrade..)
- Focal Component Speakers
- Interior Illumination (Under Dash - On/Off with Dome Lights)
- Not sure if I want to Turbo the Stock Engine or Swap for a DOHC first. I know the Engine Bay isn't huge, but I am contemplating dropping an H22 in it. Still on the fence..
