civic hatch jdm b18c swap need some help
brian.t
Hi i recently pick up a 95 civic hatch that has the jdm b18c with the lsd tranny for 2400.The motor came with a skunk2 intake manifold,blox 68mm throttle body,aem fuel rail,aem fuel filter,and a aem intake ect.The reason i got the car for so cheap ,is it smoke's sometimes at high rpm's and it need'ed a little tlc,and the guy done put way to much into the car to keep going.What im asking is,should i go and replace the head gasket on it and if so can i use a b18c1 gasket kit for it cause im not really sure and should i have it machined why im at it thanks and any info will help.
Jay Jay
Administrator
Premium
Welcome to the site. Are you replacing the head gasket because of the smoke? The smoke could be coming from a bunch of things. Do you know what color the smoke is?
brian.t
its white and it only does it at high rpms its not a constant puring out.
HondaP_wer
Do a compression test and a leak down test. That's a good start. Make sure the engine is fully warmed up though. Check your radiator hoses for stiffness too. Or even a exhaust contamination in the coolant test. You might smell combustion gas in the coolant if it's bad enough.
MistahJuice
100% real juice
Yeah white is generally coolant so head gasket is a good guess, but u don't want to spend more money then u have to. DO the above and like stated if you are losing coolant and or have murky chocolate milk looking coolant/oil then its most likely the head gasket
