ya but 92 vx's are super wired for vtec!, super vtec!Originally posted by BioHazard
and arent all 92 models pre wired for vtec regardless if they have a vtec motor
wagons own! I got a 91 sedanOriginally posted by hothondacivic
u need 2 stick with the d15 i have 1 and ive got 112 mph out of it but i got a k&n filter and a no cat exaust. by the way its a 90 civic WAGON yall!!!!
why do i highly doubt that concidering an ex with 30 more hp and better aerodynamics tops out in the low 120s. and no the b16a2 isnt the best.Originally posted by FusionRnD
I have a 94 VX with 193,000 miles on it and I still smoke other civics... haha, no b16's mind you but mine holds its ground.. on the stock tranny I topped out at 135 but I replaced the gears with and si rebuild so no my governor kicks in at 115 buts its got plent left to go, If I didn't have that in it'd easily go 130. I have greddy (greedy) headers, Intake with larger cone filter, 2 1/4 inch exhaust from the header back with glasspax as my resinator hi flow cat and a Tsudo Muffler. I have an AEM CAM adjustable cam gear, and pulleys. after all this I still get about 35 mpg, not too bad. but if you can afford to do the swap the b16A2 is the best (hydraulic clutch)
After everything I've listed in the earlier post is good for about 30 hp plus the vx is lighter due to the whole "economy" thing.Originally posted by handlebarsfsr
the bigest problem with the vx is its designed for economy, when you increase the air volume and fuel, and decrease restriction in the exhaust plus with taking away a lot of drag on the pulleys you increase hp everyone agrees plus switching to si gears removes the vx's poor top end so at high speeds you are at the rpm level where hondas make their power. Thats what I'm sayin so I'd prefer not to be called a moron because I do know what I'm talking about.Originally posted by handlebarsfsr
if you think intake and exhaust adds 30 hp to a vx, i want whatever your smokin.
You need to chill, Yes I have gone in the 130's on the stock tranny; I'm not the first I won't be the last. What have you got? handlebarsfsr...Originally posted by handlebarsfsr
you've been reading manufacturers websites for that stuff huh? yes the gears do help, but you claimed 135mph before that. and gears dont add hp either, they just give the car more mechanical advantage.
