ckf sensor
adri70
Hi guys I'm not sure if this is the right place .
The problem that I found in my 1999 civic SI is the engine light that come on. I check the wire of the CKF sensor that come from the time belt to the connector, and I can fell with the finger that the cover of wire is broken, now I assume that the wire is broken too. I try to fix it but is very hard to do, because there is not enough room to work. My thought is try with the ckf trick any suggest?
how to do it or another solution?
