Clutch grinds when fog light is turn on
KINCHEE
Dummy Role Is All I Know.
:x I just search through the archives and no help. Yesterday I got my fog lights for my EJ2 coupe and it took me like 2 hours to get it hook up but first i had to remove the old wiring that was install by the previous owner. Anyways i got everything hook up correctly I think, then when it got dark i tested the fog light out while i was driving and i heard this grindin high pitch noise comin from my clutch. It would do that everytime I step on the clutch to shift. At first I thought my clutch was acting up NOPE. It happen when i turn the lights on. I think there is a hot wire somewhere and i didnt properly attached it. Everything seems to be alright, I will take some time tomorrow to go back to scratch and rewire things. Anyone had this problem before?? Any help would be appreciated. :D
Newspeed
isnt the clutch mechanically connected therefore your wiring job could not have cause it to grind?
KINCHEE
Clutch was fine before the install, it happen afterwards and its difinitely my wiring. In order for me to shift without the grinding i have to barely press all the way down. Its some eletrical thing.
Newspeed
maybe, but what would wiring have to do with the clutch? the clutch doesnt have any wiring as far as i can tell. anyways good luck
ShinsenTuner
CC's Youngest OG
Stop paying attention to how pretty your fogs are and start paying attention to your shifting, lol.
KINCHEE
I rarely grind my clutch and this is ticking me off, and whats funny is that i can jump start it without turning the key to ignition when i have the lights on. wtf????
Blazed
f**k The Powers That B
one cant have anything to do with the other....:no:
Newspeed
you got yourself a clutch problem. better take a look at that first
mymmeryloss
RHD is where its at
did you take your tranny out to wire your fogs?
anekin007
Unregistered User
high pitch grind? and u say u can push start ur car with the lights on without turning the ignition? the sound would probably be the start hitting the flywheel and the problem seems to be the wiring. the lights is somehow wired to the starter. did someone do the light trick on your car? its when u cant start the car unless the headlights are on..
GTIUNIT
very yes...
where did you get power from? it almost sounds like you tapped into the starter lead.
KINCHEE
no i didnt take ou ty tranny to wire the fog, why should i? i just follow the old fog light wiring and just went that way. im not sure if i got loose wire somewhere, there is this groundin wire that is attached before the switch relay. i might have to ground it completely with electrical tape, i might also be tappin into something.
i got to get this fix cause im havin my alarm install tomorrow.
