Clutchmasters Questions
edhgreatone
I am going to purchase a ClutchMasters Clutches and Fidanza Flywheels Combo. I don't know much about clutches but would this be stupid to buy before i get my turbo or should i do it after? Also why axactly is the Fidanza Flywheel? Is this a big upgrade does this just make my rpm's go up faster? or what? please help.... and is stage 3 clutch really hard to drive everyday on?
lanojp1
if you get a clutch now by the time you turbo it will be broken in...a flywheel does make ur engine able to rev faster cuz its lighter than stock...
DirtyD
also, regarding the flywheel, the lighter you go, the more responsive your revs will be which is not always a good thing. If you were reving at 4000 and then let off the gas your car would slow down more rapidly as well, it would slow revs more rapidly the lighter your flywheel is.
Sound Streamin'
Boost or Die
My bro put a super light fidenzi on his sohc ZC. It's so light the damn thing will sometimes stall at idle because it doesnt have enough flywheel inertia to keep the engine running. It's also a lot harder for him to launch the car now aswell. So don't go overly light.
edhgreatone
so the one that comes with the combo is 6.5 lbs is this too light?????
nd4sped
Moderator
It would be good becuase of the break in period. The flywheel is less weight which means less rotational wieght in which the engine has to work less to turn it.
edhgreatone
so i plan on turboing would this 6.5 lbs flywheel be too light???????
