94hatchgsr
So here is the details. 94 hatch. Has a 96 gsr motor/tranny swap. Car still uses factory obd1 wiring with wiring ran to correct pins on ecu for vtec engagement(everything is soldered and heat wrapped). It's running a chipped p28 ecu(not sure what it's chipped with or what programming). All gauges working properly(tach, speedo, temp) but no vtec engagement. Ecu was throwing codes 4,6,&9. Replaced dizzy and reset ecu. Car pulled hard with vtec engagement through 1st and 2nd them immediately threw code 6 again. I have replaced the coolant temp sensor already(twice actually) and chased down wiring again only to have same issues over and over. As soon as I hit 6k rpm cel light kicks in and goes to limp mode limiting it to 3200 rpm. I'm lost to where to look next. Any help would be gladly appreciated.
