fronx
I got code 9 on my d15b Vtec. The car backfires at high rpm so i started doing stuff to figure it out. I changed my Ignition wires, plugs, Fuel pressure regulator. I cleaned my IAC valve and VTEC screen as well. At first the problem seemed like it was gone but today i floored it and it still boggs out and backfires at high rpm. I couldnt tell you how high because i dont have a tac. Would the timing cause this effect? is there something else simple that could be the problem? the car still runs great other then that.
Also did Valve cover gasket, oil cap and Fuel filter
