Compression ratio?
Boricua_Civic
i have a 2004 Honda Civic EX (D17A2) and i want to prepare it to put in a Turbo kit later on in the year. i understand that i have to lower the compresion ratio, what all do i need to do? any info will be helpfull, Thnx
2fast.
New pistons will do it.
BlueSiclone
Master Ricer
More specifically, just plan on the entire bottom end if you are doing that.
Bearings, rods/pistons, balance and blueprint...a micropolish on the crank...get it done right.
I'm going with 9.0:1 CR..If your putting a big ass turbo on it then maaaaybe 8.5:1 but 9.0:1 should be just fine...you can find some good deals out there too
giggitySI
u would be fine wit jus swappin out pistons, u could get a medium size turbo and push about 15 pounds and be fine if u got lower compression pistons, 9.0:1 should be good try to shoot for the b18b1 compression a lot of people turbo those motors cause of the compresssion, thats what i would do, jus make sure u go wit a lil head work, after that, cams, valve springs, retainers ect. u should be good man jus make sure u do ur research
