student302
So, a bit of back history. I bought my first car 3 months ago, not knowing a ton about cars, I've been relying on friends to try and fix it up. It's a 1995 Honda Civic SI Coupe (D16Z6). Car needed a new clutch, bit of body work, and needed to fix a pretty bad oil leak.
I recently swapped in a B18B1, test-drove it around the blcok last night and found out the transmission is shot.
This morning I woke up, went to check on it (wasn't run at all since last night), and there are 2 massive leaks, coming from I don't know where.
Power Steering:
The power steering is leaking directly under the resivoir, I've checked the hoses and everything appears to be tight, I have no idea where it's coming from as the resoivoir and all the hoses from what I can see, are clean and don't have any fluid on them
Coolant Leak:
The coolant is leaking from directly under the center of the car, about where the drivers/passengers seats are, all the way to the trunk. I took some pictures of this as I have no idea where it's coming from, and why it's leaking so much even when the car is not running.
Power Steering:
Coolant Leak:
![](http://i116.photobucket.com/albums/o7/Hexbomber/1995%20Honda%20Civic%20SI/IMG_20120901_120856.jpg)
![](http://i116.photobucket.com/albums/o7/Hexbomber/1995%20Honda%20Civic%20SI/IMG_20120901_120908.jpg)
![](http://i116.photobucket.com/albums/o7/Hexbomber/1995%20Honda%20Civic%20SI/IMG_20120901_120915.jpg)
![](http://i116.photobucket.com/albums/o7/Hexbomber/1995%20Honda%20Civic%20SI/IMG_20120901_120946.jpg)
