benny boy
I need your help! My 89 Civic DX will not start. I was driving home and the engine just shut off. I tried popping the clutch without luck. Got it towed home and I can't figure it out. I have spark. Fuel sprays at the filter when I turn the key. The main relay gives three clicks. The timing belt is not broken and I am not getting any codes from the ECU, just the one blink to let me know it's there. I tried pouring a little gas in the throttle assembly and it still wouldn't start. The plugs, wires, distributer cap, rotor inside the cap, valve cover gasket and grommets inside have all been changed this year. A few months ago it stopped starting by the key. If I turned the key to the run position I could start it by jumping the starter with a screwdriver. Because of this I installed a push button on the dash. I just turn the key to run, push the button and then turn the key to off whenever I arrive wherever. This has worked fine. Any help/suggestions would be most appreciated.
