CRANKS!, but wont start.HELP
GEE-Zus
1998 cx d16y7 (auto)
OK so i was driving my car last Tues, and i only got to drive it not even a mile.it shut off on me while driving.got it towed to my place.
i replaced my fuel pump,plugs,wires, and coil. and still nothing.
i noticed there was oil inside my intake manifold just below the throttle body.
HELP someone
mymmeryloss
RHD is where its at
Do u have spark and fuel?
Tiny bit of oil in the intake is normal.
JeffBel
Check your Pcv and valve cover gasket, oil on plugs is a no no. Did it start after you swapped the plugs?
Your engine needs 4 simple things.
Air, fuel, spark, and timing.
GEE-Zus
plugs
wires
fuelpump
ignition coil
pcv
all changed,
i cleaned my throttle body and tried to to jump it and nothing
how could my timing be off if i havent done anything to mess with it?
JeffBel
Next check all your major wired components: injectors, map, I'm drawing a blank on others atm.
AlaskaB16
DOING WORK!
Can you hear your fuel pump prime? Have you taken your main relay out and did the solder/contact cleaner mumbo jumbo? Oily plugs is a no go though. That will kill your spark for sure. Has you car over heated? Blowing any smoke? Check engine light?
emerican
^ x2
and the timming could have jumped even though you didnt mess with it dosent hurt to go ahead and check it.
GEE-Zus
i took my throttle body off cleaned it plugged everything back on it, no smoke and it hasnt over heated on me ever ,
ill check the timing belt,i cant hear my pump turn on inside my car, thanks for the help!
