Creaky Window
98civex
For some reason my 98 civic when I have my driver's side window rolled all the way up, makes a lot of creaky noises that sound like theyre coming from the door panel. The bumpier the road, the more noise it makes. 95% of it goes away soon as window is cracked open. This seems like a stupid problem.. but it's annoying. Anyone else experience this?
98civex
no one?
R3dline
its just the plastic the door is made from, when its closed it makes it really tight and rubs more, when its open its loose,
98civex
No fix? I just noticed today in the rain there's no noise at all. Weird?
98civex
Upon inspection I noticed my door is a bit misaligned causing the weather stripping around the window to not seal right when it's closed causing the noise. For now I sprayed some silicone grease on it and it seems to be quiet until I get a chance to do a real fix.
LXDriver
More HP is always good
I got a similar problem. My rear passenger window rattles 2 when its all the way down, any ideas of what it could be?
98civex
Window or panel rattles? I'd make sure it's tight on it's track or check for broken panel clips
LXDriver
Well I'm not sure if its the actual window or panel, but it only rattle when its all the way down like I mentioned, which is like 3/4's down on 6th gens. It didnt do that before and it just started after a while out of nowhere
