cruise control stoped working
ervstr
boosted_ek
at a point my crusie control was working,but now it just stopped.i checkd the fuse and its good.when i push the cc button the button lights up but the word cruise control on the cluster dont.idk what else could be wrong.
xWIREMANx
I know this is a little old but maybe you are still looking for help. First off are you sure it is not working? Is just the light on your cluster not working and everything else is fine? If it still isn't working then there maybe more than one fuse in the car for your cruise even if it is not labeled for cruise. You should check every fuse in the car and under the hood with a meter. Replace any that are bad and test the cruise again. If it still doesn't work I would imagine it is the activation switch on your steering wheel or the plug that goes to the steering wheel.
