Cruise not working
txcivic79
Hi CC,
My cruise does not work or has not since I bought it a few months ago so I took out the switch because the light did not turn on on the button when pushed, the bulb is burned out. Does a burned out bulb in the switch cause it to not work? What would be the next thing to check and trouble shoot?
I tried switching the bulbs around (there are 2 in the switch) but it still did not work. The "cruise control" light on the intstrument cluster does not turn on. Any thoughts or ideas?
[/URL][/IMG]
cgpEJ6
noob
The bulb won't have anything to do with it. Check the fuse, I know that happened to me once before.
txcivic79
I checked the fuse, the light on the switch does not come on with it out but does with it inane the fuse looks fine.??
txcivic79
So I checked the fuse in the dash, 14 and 25 I think it was and they are fine. I also looked under the hood and all of the connections are in place and nothing is unplugged that I could visually see. I also checked the brake pedal, I'm assuming the stopper I have read about is the one that turns the brake lights on/off as well. That is there and worked as well.
What would be the next thing to check?
