ctr center console.
Evan.
iTrader EVERYthing
Heres what im trying to replace:
Armrest
Shifter Console
Cupholder Assembly
A couple questions:
1) Does the armest eliminator fit into ek coupes since it came out of a hatch? does it bolt in? (i dont want it wiggling around).
2) Is it possible to get the shifter / center console from an ek9? The part where the shift boot / etc. is or is it just the same as mine now, but painted black? will it work with the armrest eliminator?
3) Is the cupholder assembly different fitment wise than any of the other ones? for instance 99-00 or 96-98, or do you need the ek9 center console to bolt it up?
NOFX
I'm NOT eran!
They fit perfectly. The cupholder section in front is the same, so they have to. For the armrest console there is a bracket you need to remove though (if you want to replace it with the delete). Don't worry, it's only a bolt or two.
I know some of them are painted a non-glossysilver too (by Honda). I think that's only in the Type Rx though. Again, all the parts should work together.
The actual cupholdres are different, but the rest of the piece should be the same.
ryanM
the fitment is the same on everything except the armrest eliminator. theres a bracket there that you have to unbolt, cut your carpet a little to slide it out, and bolt the ebrake cables back down. its SUPER easy.
NOFX
I'm NOT eran!
Oh yeah, and the tabs at the back of the console delete break almost all the time. I've noticed this in most hatches that I've gotte into. Either they're broken, or partially broken. :( So if you can find one new, or you can see the two tabs are still on there and you can get a nice deal, go for it.
X-aCuTiOnA
W.W.H.D.?
I actually have then shifter console from an EK9 if ur interested. PM me
