CX trailing arm interchangeability.
union made
Working on a '92 CX. Will the trailing arms from a' 93 EX four door fit? These are disc brake units with good bushings,; mine are shot. I'd like to kill two birds with one stone.
ReedMann
Yes, they will fit. All 94-01 Integras and 92-00 Civics have the same rear trailing arms. They will bolt right on, with the exception of the e-brake cables. It would be best to try to get the e-brake cables that are currently on the rear trailing arms you plan to buy. If you can't, any 94-01 Integra or 92-95 Si cables should fit.
mymmeryloss
RHD is where its at
Rear disc ftw!
union made
Had new bushings installed in the '93 trailing arms, new LCAs, disc brakes, shocks, and had Lucore automotive drill out the broken bolt from the compensator arm. Drove home with no compensator arm, and switched everything at once. Took me around 7 hours. I'm 64 and working with the car on jack stands. You should be able to do it faster. Looks great. When I first went to look at the Cx, it had spoked mags on it. I got down to look at the back brakes, because they looked strange, they were so small. A cosmetic change that cost me about $850 with new tires and alignment. Feels worth it, looks worth it. Damn,, I'm glad it's done. Thanks to everyone who helped.
