anyone in texas want to get rid of a d16z6 longblockor even a d16y8? I'll pick up as long as the longblock is in good condition...
I have a D15B VTEC for sale... almost exactly the same as D16Z6... more aggressive cam profile, and higher horse power outputCrIaVcIeCr said:anyone in texas want to get rid of a d16z6 longblockor even a d16y8? I'll pick up as long as the longblock is in good condition...
As I said it's almost exactly like the D16Z6... they have the exact same head and intake manifold (although the D15B has the most aggressive cam profile of any Dseries VTEC engine, hence the higher hp output)CrIaVcIeCr said:Well, can i use all the stuff from my z6 such as the ecu, exhaust and intake manifold on your d15b? If not thats why im looking for a d16z6 so i can just put in...
Killa_CiViC said:As I said it's almost exactly like the D16Z6... they have the exact same head and intake manifold (although the D15B has the most aggressive cam profile of any Dseries VTEC engine, hence the higher hp output)
The only difference between the D15B and the D16Z6 is the cam, the crank, and the rods (shorter stroke, same diameter pistons.... better for revving higher than the D16Z6 is)
As far as performance parts... everything that will fit on the D16Z6 will fit exactly the same, except for the crank shaft and rods... in which case you'd need de-stroked Z6 cranks and rods.... but you'd never really mess with those anyways, unless you were running like 10+ pounds of boost.[/QUOT
i would like to buy the d15 engine from you
CrIaVcIeCr said:I already have it in my car!!... Thanks for the engine Jason. Runs perfec...
-Charlie
