First question would be compression on the pistons/rods... I've heard that lower compression is advantageous to a Turbo setup... can anyone explain?
The turbo is a T25 and the block is gonna be completely built... both top (eventually) and bottom (before the swap)...
I'd like to get up around 200 horse and get used to driving a turbo vehicle....lol.......then after I rebuild the top (and win the lottery 8) ) drop some mega boost in there....
So what I'm asking is... Is there a good piston/rod combo that would work well with a lower boost setup and a higher boost setup and what would you recommend... (If they differ I'm mainly after the best combo for a T25 low boost setup ..200 horseish) Also, they would have to be able to withstand a small shot of nitro...
Thanks!
Thanks!
