Brennan
hey....so i was trying to look around for a thread on this swap but i couldnt find one. I have a d15b thats going into the 98 civic. Im getting confused on what exactly should be swapped over. The intake mani, distributor and alternator so far is what im guessing. However do i use the d16 injectors? just take the whole rail? should i stick with my d16 ecu (p2p) or find a po8 or p28? and im trying to use the original wiring harness from the d16 ...im not sure what to do ive hit a stump. And if i stick with the original d16 harness what should i do about the knock sensor and the crank sensor? and would i need the crank pulley and the timing belt from the d16 too? AHHH...any help at this point would be appreciated...thank you
