Ramses
Hello,
I recently picked up a 96 Civix EX which has had a D15B7 dropped into it at some point; so from vtec to non-vtec. I believe the ecu has been swapped out as well and don't think it matches the body or the motor; it's a p2p a31. Whoever dropped in the motor took the trouble to replace the sensors required for OBDII, except the crank fluctuation sensor. So the only code the ecu is throwing is for the missing vtec connections and that sensor. I think both would be solved with a non-vtec ecu. I need to get through WA emissions and I don't think I can do that with a code being thrown.
In short, is there an ecu I can use for the D15B7 with manual transmission that is OBDII?
Thanks for any help or advice.
