D16 vs B series
Status
Not open for further replies.
str33tpr3p
I currently have a d16z6 in my 1993 si hatch , i either want to boost that or swap for a b series engine,
I know with the b series ill have more choice and potential but from what ive read i hear a boosted d series isnt to bad either ,
Just looking for some imput !
Great Thanks
s_crowley 17
youll get more power if you boost it.
str33tpr3p
Yeah but the power ends there if i put a b series i can turbo it and still have much more power
lulzadr
The Game.
Boosted B will have more power than a boosted D, obviously. But you'll also be spending more money for the swap and then boost if you go B.
98 EK Hatch
Big Daddy Dumplin
well it sounds like you just answered your own question.
B Series > D16
Steven.
Formally Green 91
vitara turbo D16z6, guys getting 500+ hp with this turbo set up, search it.
D16 > B series.
somejaykid
i'm a mod now
i'll go with a b-series engine on this one
CHILD
All Day, All JDM
turbo d.....there's way too many with super high numbers off of a boosted D and its always cheaper building a d than a B.
+1 for turbo d
zeesixed3
+1 for turbo d
definetly agree with the d bro just build it first
1 more for D
98civb18c
good luck DDing a 500hp d series.
JRSC and bolt-ons, tune a B and your at 250-300 and its reliable.
JRSC and tune a D you might get up to what a stock B series puts out and its reliable.
Any fully built motor with 500+ hp is going to be really really hard to make consistantly reliable. Depends what you need the car for.
B swap it, then if its not fast enough, turbo it.
Docta2002
It's all about money. It's obvious a turbo B is better than a turbo D, but a turbo D is better than a stock B.
Getting a B will cost you alot, and for what, so you end up with a stock B? Forget tha man, spend the money on the D, and you'll definitely have alot more fun with that engine, unless of course you have enough money to buy a B, build it for boost, and boost it.
A D16 with eagle rods $280, vitaras $130, ARP head studs $90, ACL Race bearings $100, Cometic HG $70, and w/e else you might wanna throw in is gonna cost you wayyyyyy less than a B with the equivalent parts.
CHILD
All Day, All JDM
everyone isnt shooting for 500whp out of a d or a b series for that matter, the point is is that its possible and for a lot less than a b. 250whp is more than enough for the average honda dd
civhatch92
That's my honda.
Just turbo the D... it can still put down enough power to satisfy!
str33tpr3p
Great thanks guys , ya ill probably get the turbo in and then maybe work on some internals get the boost up to around 15 , i think i could run about 8 on stock internals with a good turbo set up.
But yeah im thinking about staying with my D series after all that .
Docta2002
Agreed! I'd be VERY HAPPY with boost and pushing 250whp. You get the turbo sound, you get kicked back in the seat, etc, etc, its much more fun and cheaper...
Unless you're one of those guys who just wants the most amount of hp you could have just to say "I gotta civic pushin 545 to the wheels" only to blow it within a year... I'd rather have 250whp for a few years prior to it giving problems..
Oh, and I've heard of guys with Ds making around 400whp w/ stock internals but I would NEVER try that! Just imagine the PIA of fixing that, even if you already have all the parts... And I got all those parts (in my previous post) and I'm only N/A... I chose to go that way cause of my future plans to boost....
Another thing, building a D, regardless if its for boost or not, is a great opportunity to learn how engines work and how everything works. Then if you ever choose to go B, as time passes, parts will be cheaper, you'll have more knowledge, and have less down-time while building.
str33tpr3p
Yeah its my first car i just want something with a little whip and a place to put all my hard earned money into and get some experience !
newtron63h
since you have the D, might as well stick with it. as long as you are looking for a DD that has some GO.......a turbo D will handle that plus some. id suggest a good solid bottom end build though. just adding low boost(say 5 psi) increases combustion chamber pressures ALOT, then if you go with more than that(say 10psi) thats a huge increase in pressures . gotta make sure you have rings that are sealing good, and ur pistons, rods, and crank are gonna hold up. other than that...........should be no problem.
Status
