Trim sol
D16 z6 crankshaft pulley removel (need help). updated (crankshaft holding tool)
my crankshaft pulley seperated . I need to remove bolt and install new pulley. I have a 1/2 breaker bar, cheater pipe, and pry bar for flywheel. what else is necessary? I plan on tonight spraying with penetrate oil. any more advice. thanks trim sol PROBLEM FIXED the best way to remove pulley requires a crankshaft holding tool. this can be purchased on ebay. this and 17mm socket and 2 (1/2) breaker bars. job was simple. also purchase a new pulley key. I repaired with a car lift in 1 hour.
