D16Y8 build help!
CIVIC_VTEC
LOW AND SLOW!
hey guys, i recently blew a rod in my 99 ex (d16y8) so i plan on dumping about 2-3 grand in it. I plan on doing the regular I/H/E, then running 12:9 comppresion. would it be a good idea to get rods, and pistons? i know i know, why not just buy a dohc? well for the fact that i love single slammers, good on gas, and they have pretty damn good acceleration. would it be best to put a z6 head on my y8 block? then bore it out?
Trekk
Do a B swap, they all get good mpg. Spending all that money to stay NA will just make you a hair quicker than a stock B. I'm all for going FI on single cams but that's it. If you really want to stay single just pick up a used motor and call it a day. Running high compression isn't as simple as putting pistons in. You are going to need a good full tune to make it run well.
young_
out on bail
This.
And a b swap is faster than your d16Y8.
crash!
Avi, pull your socks up.
This. Why in God's good grace would you spend that much rebuilding a D when with that you could do a lightly built B series? I spent about 2500 on my GSR build and I'm extremely happy with it.
Honda4ever
i would get a h22 because they are pretty cheap but u need harneses and mounts for it to fit and with i/h/e over 200hp right there.
crash!
This too. The reason I say B is because H series parts aren't as interchangable and easy to find.
emerican
if you really want to keep the d rebuild it and boost it for that budget then itll be worth it.
ne0tas
Stock b series>semi built d series. Or go h22/f20b with h2b kit and bam there is your raped d series motor
