D16y8 or y7 engine
ClifftonN
I have a rod knocking and im needing a cheap bottom end to rebuild so i can just do a quick swap. Thanks I live in Norman,Ok
DeviousJuney
D16y8 cause thats vtec not sure if y7 is vtec though. if it has a soloniod behind the distributor on y7 then yeah choose either. but for vtec comfirmation go y8
MotorMo
D16Y8 and D16Y7 bottom ends and different in stock piston size (compression ratio) and a possible knock sensor on the back casting in the Y8. Are you swapping out your D for a B, and just wanting a cheap swap in until then?, or just wanting to 'build' and D series?
